David Kurtz (142.165.214.206)
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, January 26, 2004 - 11:38 pm: | |
anybody ever changed manual to power steering on a 4106? Parts available or what's involved? Thanks |
Fred Forker (207.254.27.86)
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, January 27, 2004 - 1:07 am: | |
I have had Sheppard power steering on my 06 for past ten years works good. you will need the steerin gear unit,a 2380206 tube assy (drag Link), 1 ea 2244570 U bolt (MCI # 07-300-01), about 70 inches of # 8 Air quip hose,Rethread old U bolts down to 5 1/2,make new bracket for air level valve on new steering gear.If you do not have the steel line from front axle to engin compartment you have a big problem??. the engin will need a hydrolic pump mounted on the adapter at end of the blower then a oil tank and filter and more hoses. Mabe $2000.00 a good stary |
FAST FRED (63.233.189.3)
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, January 27, 2004 - 5:48 am: | |
Some folks choose the Air O Matic , which is enough assist for parking, but does not change (reduce) the number of turns lock to kock. A fellow at Jacks Bus Gathering had one for about $400 to sell, but I don't know how to contact him. Perhaps A WANTED in the flea market would surface the unit. FAST FRED |
Gary Carter (68.25.114.21)
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, January 27, 2004 - 6:45 pm: | |
I changed the Vickers power assist to a Sheppard on our 4106. It was eazy. In your case you need the sheppard unit and a power steering pump. You will have to run hydrolic lines from the engine, but not a major problem. Call Nimco and they will send you a change over kit which should include a drag link, sheppard box, and pump. Good luck |
Tim Brandt (Timb) (12.8.192.60)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, January 28, 2004 - 11:31 am: | |
Sorry wrong post moving |
