Al (209.252.244.75)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, April 11, 2001 - 10:08 pm: | |
I am changing from stick to a v730 I have a 4 1/8 to 1 rear axel with 1100x22.5 tires. Am I right with my numbers that I will only be able to run 66mph? I just got the manual on the V730. Can any one with a V730 in a 06 can you tell what kind of speed I can expect? Thanks Al |
06 Bill (208.247.199.45)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, April 11, 2001 - 10:41 pm: | |
Al I have a 4106 with a V730 & 8V71. The rear end is 4&1/8 and my bus will run about 72MPH against the governor. This is by the speedometer but I am going by alot of stuff at that time. The tires are 12-22.5. I do not have a tach so I can't tell you the RPM. P.S. Pulling a VW Golf on a dolly too. |
FAST FRED (209.26.87.76)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, April 12, 2001 - 7:45 am: | |
IF you keep the same rear [no choice its highest made} you usually LOOSE about 8mph due to the difference in the gearing. The ONLY way to get some of the speed back ( besides killing the engine thur over reving}is to go to 12R24.5 with new wheels and tires. Big bucks for 3 or so mph. IF you wish to contemplate all the variables , go to this fellows web site , he has kindly created a speed/rpm calculator. http://home1.gte.net/res07rfl/ There is also an ongoing GM discussion at http://groups.yahoo.com/group/gmc-busnuts/messages/5165?viscount=-30 where speed /rpm / lugging is being discussed. FAST FRED |
Frank Allen (205.188.192.54)
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, May 14, 2001 - 1:58 am: | |
You should be able to run 75 mph, will loose 3 mpg fuel , the gear is right where you need to be since it is a highway gear for the o6 and theres not a better one avail, there is a lot of opinions out there on this, but what i have told you is the truth period, 75 mph, 7 to 7.5 mpg and thats the way it is i have one . i think the 7/30 ruins a good bus , but it depends on how you look at it and what you are willing to trade off. Frank |
Frank Allen (66.26.215.113)
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, June 24, 2001 - 1:51 pm: | |
Forgot a few details, i have a 4106, rearend is 410 ratio, tires are 12/22.5 top speed is 75 mph, fuel useage is down from 10+ to 7+ , top speed is down 7 to 10 mph . Frank Allen 64, 4106, 2626 |
