joe shelton (64.222.146.49)
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, November 03, 2003 - 10:15 am: | |
My 4106 has a V730 Auto with a Stone-Bennet air shifter. Will a V731 work as a replacement and what modifications are required to installThanks, Joe 4106-2119 |
TVP (63.122.65.97)
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, November 03, 2003 - 4:19 pm: | |
Hey ... the 1 on the end signifies electronic shift ... the trans will bolt right in but the you'll need the electronic switch to go with ... TVP |
Bob Gallo (66.142.52.232)
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, November 03, 2003 - 11:47 pm: | |
There is quite a wiring harness involved. It should be available from the donor bus. The Allison manual spells out the parts for the harness, ECM, and control panel. I've driven a couple and they seem fine. My research points to the possibility of changing the valve body from a V730 and install it in a V731 to make it a mechanical transmission. Don't know if anyone's tried it? |
