Bill Upnortdareh (64.12.96.105)
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, October 24, 2003 - 6:01 pm: | |
And I don't mean by the sun.I have 4104 with neg ground, I was in the coach today, master switch was on for about and hour, went to turn it off and the red light was not on in the rocker and I could not turn it off.Took the switch panel off and check the wires, put the light on the switch and all three posts were hot. I had the clip from the light on the hand brake lever, so I check the ground wire on the switch it was hot on the body. The switch is about a month old . So I pulled the ground off the switch and it worked fine with no red light. Everything else worked fine in the coach. So I just let it sit to contemplate the problem and went on with my day. Went back 3 hrs later and everthing is back to normal and working fine .------Any Ideas -Bill--4104-4032 |
