Bob Baldwin (Bob4106) (66.56.100.54)
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, October 14, 2003 - 7:53 pm: | |
For the do it your selfer. what would be good to use? I have a 4106 and knowest some in their now.But someone said try the foam 4x8 sheets at lowes. I knowest that the R value is real low.Is their any thing else that could be used? Don't know about the spay foam or how much the cost is? any help would be nice thanks |
Peter Broadribb (Madbrit) (216.67.217.43)
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, October 14, 2003 - 8:22 pm: | |
The regular white or blue foam sheets are low in their R-Factor. I was going to use Celotex, but this has gone from the market. However Dow Industries who bought out Celotex, have a similar product range: It is a product called Tuff-R and Super Tuff-R. They both have the same R value per inch, which was R-7.2 and is now R-6.5 due a different blowing process and to a different ASTM number. http://www.dow.com/styrofoam/na/iso/tuff_r.htm Peter. |
Larry (208.18.102.70)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, October 15, 2003 - 9:27 am: | |
Using blue board? Read the warnings on it, this product must be covered, can omit harmful gases. The info we have is that it must be used towards the out side (between stud and siding). |
Phil Curtis (152.163.252.163)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, October 16, 2003 - 7:52 pm: | |
If you go with the r/m board 1 inch thick double thick you end up with about 6.5 R make sure it is the foil backed one.also 1/8 the cost of spray foam my coach stays cool in the summer and warm in the winter |
