John Rigby (63.185.80.189)
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, August 18, 2003 - 11:43 am: | |
According to dietroit when you set the govenor at full throatly, no load, at 2150rpm. the actual rpm under load is always 200 rpm lower = 1950rpm. So do you set the govenor at the max rpm you want at no load or at full load?? Thanks John |
Geoff (Geoff) (66.238.120.35)
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, August 18, 2003 - 12:32 pm: | |
It's called governor "droop" and it allows for 150 rpm drop to compensate for the inherent slop in the mechanical governor linkage. So if you want your engine set at 2100 under full load, you set it at 2250 no load. I don't know where you heard 200 droop, it is 150, and if you have a tight rack it comes out even less. --Geoff '82 RTS CA |
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, August 18, 2003 - 2:45 pm: | |
Geoff I called the tech dept at DDA in Dietroit. They were the guys that informed me of the droop. I was curious cause I always hear people say set the 671 at 2150rpm, but with a 150 or 200 droop do they set it under load or off load?? Thanks John |
Geoff (Geoff) (66.238.122.245)
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, August 18, 2003 - 6:43 pm: | |
A lot of people set the no load at 2300, so then it would be at 2150 under full load. |
Steven Gibbs (12.148.43.7)
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, August 19, 2003 - 9:46 am: | |
How hard is it to set the govenor? Can it be done by someone in the driveway with a good tach and without taking anything apart? Suppose I could look in DA book but since this thread is here.... Thanks, Steve G. |
Geoff (Geoff) (66.238.121.11)
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, August 19, 2003 - 11:18 am: | |
It is easy to set, look in the book for details! |
Dave (65.56.236.10)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, August 20, 2003 - 8:06 pm: | |
Is there some one out there that might scan that section about setting the governor on a6v-92t and send it to me,I could use all the help i can on this matter. I should get book on motor in about week,but need to get governor set befor that. Thanks very much. Dave. |
Dave (65.56.236.10)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, August 20, 2003 - 8:11 pm: | |
Sorry forgot e-mail. djroy@mpdu.com Thanks again. Dave |
