Doug (204.182.81.207)
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, March 16, 2001 - 11:36 pm: | |
Buddy, It is most likely unburned fuel caused by low compression. There is a small possibility the smoke could be caused by a faulty injector. First make sure the valve clearance and injector timing are set properly. Once you confirm the settings remove the exhaust manifold and run it to see which cylinder is smoking. If all are smoking low compression is most likely the problem. If one is smoking swap the injector with a cylinder that is not smoking. If the problem moves with the injector, the injector is bad. If it doesn't move low compression in that hole is the problem. Good Luck, Doug |
