Post Number: 1248 Registered: 10-2006 Posted From: 99.153.142.249
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, July 24, 2010 - 6:53 am: | |
Have no idea how I lost a book mark , but could anyone post a link to the Darris B site with the fantastic RPM vs gear ratio vs tire size computer? TIA, FF |
Post Number: 1935 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, July 24, 2010 - 7:36 am: | |
www.thebouthilliers.com/4106 |
Tom Christman (Tchristman)
Post Number: 236 Registered: 1-2006 Posted From: 66.218.33.156
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, July 25, 2010 - 11:41 am: | |
That calculator at thebouthilliers is incorrect. It says to use the actual diameter of the tire for calculations. That's fine, but you'll always be off by 1.6-1.7mph from the rolling radius advertised with a tire company. If that doesn't bother you-then great! My 11/R-24.5 tire is 476rpm, times 4.56 rear end, times .88 final drive (V730) equals 1910rpm at 60mph. Easy to do yourself. Good Luck, TomC |
Post Number: 1707 Registered: 12-2000 Posted From: 71.195.124.20
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, July 25, 2010 - 12:13 pm: | |
Tom - Even your calc is off a little, 'cause you rounded UP the bevel gear ratio of the V-730. (0.875 actual vs 0.88 used) " If that doesn't bother you-then great!" Hehehehehe  |
Post Number: 1252 Registered: 10-2006 Posted From: 99.153.142.249
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, July 25, 2010 - 2:57 pm: | |
"It says to use the actual diameter of the tire for calculations. That's fine, but you'll always be off by 1.6-1.7mph from the rolling radius advertised with a tire company." To find the actual diameter the drill is a chalk mark, count 10 revolutions and do da math. OFF by 1 mph is just fine for my mental masturbation. I also discount the increase in tire diameter from centrifugal force at 75, and the larger diameter when being at Denver , where the gravity is less than Miami! YRWV FF |
Post Number: 1889 Registered: 12-2000 Posted From: 174.91.140.242
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, July 26, 2010 - 10:59 pm: | |
And here's Mallie's calculator, since we're on the topic: http://www.cwis.net/~mallie/page12.html happy coaching! buswarrior |
Post Number: 1367 Registered: 7-1997 Posted From: 24.239.15.161
Rating:  Votes: 1 (Vote!) | | Posted on Sunday, August 01, 2010 - 11:34 am: | |
No, this is not the first time the word "masturbation" has appeared on this web site. Thought you'd like to know. Thank you, Fast, for both instances. Ian www.busnut.com |
Post Number: 1896 Registered: 12-2000 Posted From: 174.91.144.79
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, August 02, 2010 - 3:19 am: | |
EH?? happy coaching! buswarrior |
