Robert Fischer (4.46.164.130)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, April 23, 2003 - 12:33 am: | |
I have just moved out of my coach. I intend to tear down the garage and pour a 45'X 24' pad with a mechanics pit. I want to build a roof over the coach which will be parked over the pit. It seems that I could use I beams 8"or 10 inch, bolt them directly to the cement pad and use these as columns, rising 14', providing 2' of clearance. I would need rafters from the top of each column extending out over the coach. additional rafters would extend the other direction & provide protection for the car since I won't have a garage. Across the rafters I can string 45' lenghts of sheet metal. I would probably have four to six columns to support this. I do not intend to attach walls or doors. I suppose a "T" best describes each column. Surely somebody has constructed such a building as I'm sure that I've seen these in my travels. Can anybody help me find such a structure? I'd like to pour this summer. I'm quite concerned about the 24' wide X 45' long wing (roof). While winds are not a big issue, any wind blowing this into the coach will be a big issue. Thanks. |
Jack Perry (Jpwinks) (68.71.200.180)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, April 23, 2003 - 8:13 am: | |
I would get a hold of all the steel erectors and fabricators in your area. They tear down about as many buildings as they put up and they usually have a stockpile of used steel framing (I beams, gerts, channels, 90 degree angels) sort of like a junk yard for pre-enjoyed structural steel components. You can start to design around what you find available, and, you WILL save HUGE money. Example: 1) A 45 x 80 x 12 building manufactured from all new components will cost around $50,000 in materials. 2) A 45 x 80 12 building manufactured from all salvaged components will cost around $6,000 in materials. Yes the salvage building will cost more labor to erect than the new building but not that much more…maybe $20%. In the end you get the building you need for at least 50% less than all new. I’ve done this already for myself, twice, and for a few friends as well. My 2 cents, Jpwinks 1983 MCIm9 |
