Mike (129.49.12.14)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, March 06, 2003 - 5:32 pm: | |
can a jake be installed on a 2 stroke? If so , how does it work since a 2 stroke does not have overhead valves? |
Lee Brady (Leeb11) (65.179.1.84)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, March 06, 2003 - 5:41 pm: | |
Mike If you have a DD 8v71 a simular detroit it has valves,ive got an 8V71 with jakes and they work great. These 2 strokes are nothing like a motorcycle engine. Lee 66Eagle01 |
Neo/Russ (66.83.53.142)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, March 06, 2003 - 5:49 pm: | |
DD two strokes use the cylinders like many 2-strokes to bring in the air, but valves to exhaust it. Therefore a Jake works because it cuts down the exhaust and makes the engine act like a big air brake. |
Henry R. Bergman, Jr. (Henryofcj) (65.194.145.39)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, March 06, 2003 - 5:51 pm: | |
Guess it kinda depends upon ones definition of a Jake and of a 2-stroke engine. Years ago we used to ride observed trials and my old Sherpa T murdercycle had a one way compression... ...release screwed into the second spark plug hole in the top of the air cooled head. The old 250 cc ring ding had no valves at all, and I used the compression release like... ...an engine brake since the brakes were soosss poor. Worked cool and sounded like a Jake too. Actually, while Detroit 2-strokes are 2 strokes, they have either 2 or 4 valves for each... ... cylinder just like a 4 stroke, but they are all exhaust valves. Sounds kinda weird, but... ....they have the "intakes" as ports in the middle/lower portion of the sleeves. In a 4 stroke diesel, a Jake alters the exhaust valve timing turning the mill into a kind of... ...giant compressor absorbing energy instead of producing it. Works about the same in a .... ....2 stroke Detroit. JAKES FOREVER!! Henry of CJ |
Loydd Fones (Tbird) (64.91.126.52)
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, March 10, 2003 - 1:34 pm: | |
I have jakes on my 8V92 and they work, but not nearly as well as they work on a 4 stroke tbird |
