robert munrow (64.12.96.235)
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, February 14, 2003 - 9:04 am: | |
My problem is I have an Eagle 10 1981 that I am converting. I needed new windshields because I was grinding inside of the coach and never realized the sparks were melting the windshields, what a dummy right, Welll I threw away the seals before i bought new ones. I bought seals from international bus parts and windshields from curved glass. both suppliers were very helpful. when the man came to install them he told me the seal was too large. I called internatioinal bus and was told that there were two size seals for a ten and they sent me the other ones the man came ou and put them in i have not went down the road yet and they are falling out can anyone help thanks bob |
David Anderson (66.90.194.207)
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, February 14, 2003 - 11:48 pm: | |
Did you put the rubber locking ring into the rubber? It goes all the way around the window rubber seal. If you didn't, call IBP and ask Rich to send you a pair. If you did, then you may have to get the glass guy to glue the rubber to the bus frame. David Anderson |
