Micheal Razberry (Razman)
Registered Member Username: Razman
Post Number: 4 Registered: 6-2009 Posted From: 70.66.128.211
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, June 16, 2009 - 8:58 pm: | |
Hello It looks like the exhaust pipe coming off the manifold needs to be replaced. The top side fitting into the manifold comes out a couple inches and then 45`s straight down for about 12 inches to a flange which joins another flange and then 45`s down to the muffler. Its the upper pipe which is toasted at the flange. Does this make any sense to you`all? The walls on the pipe are rather thin, so I doubt it would take a weld, wouldn`t last. Anyone up here in BC CANADA that can suggest where I might get a part like this? Has anyone used that flex pipe ... what would the life on it be? thanks, razman |
Post Number: 706 Registered: 8-2006 Posted From: 74.33.63.151
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, June 16, 2009 - 10:19 pm: | |
Razman, the orginal pipe on the model 05 was a cast 90 with a steel flange welded into it and was easy to repair the flanges are a stock item at most muffler shops .If the cast 90 has been replaced go to a muffler shop and have a steel 90 made.I just gave a cast 1 away 2 weeks ago good luck (Message edited by luvrbus on June 16, 2009) |
Post Number: 1527 Registered: 10-2003 Posted From: 71.58.110.9
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, June 17, 2009 - 4:57 pm: | |
Those metal flange stubs are listed in the local NAPA heavy duty exhaust catalog if you have trouble finding a stub. |
