dounan.morton (65.96.80.66)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, September 25, 2002 - 9:53 pm: | |
my brown tag N65's don't look like they will fit in my 4 valve head. it has 75's in it.this is going in an 04, 6-71. thanks for any feed back dounan |
Luke Bonagura (Lukeatuscoach) (12.90.12.102)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, September 25, 2002 - 10:10 pm: | |
Hi Dounan Unfortunately you are correct. Your "Straight Body" injectors from your 2-valve head must be replaced with "Off-set" injectors in your new 4-valve head. So when you order your injectors: 1. State the Size you want. 2. Be sure to mention Off-set injectors. Hopefully, whoever you talk to will not be too young to know the difference. I Hope this HELPS!!!! LUKE at US COACH |
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, September 26, 2002 - 6:06 pm: | |
luke much as i feared. thank you again. dounan |
Tuck-04 (207.144.133.175)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, September 26, 2002 - 7:27 pm: | |
I changed the injecters in my 2 valve head to the offset type. I had to change the whole rack but it works fine now. I went to N-60s. I have a 4.125 rearend and am getting about 8 mpg and less with the diesel genset running. When I crank my bus the next thing I do is crank the diesel genset. Tuck-04 |
