Post Number: 533 Registered: 1-2005 Posted From: 97.104.13.172
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, February 28, 2009 - 8:22 pm: | |
Hi All Just got a call from Randy - he was on his way here to Daytona for BIKE Week - His GMC 5302 & 6v92ta with C65 injectors broke down - Stuck injector - causing wide open throttle he's safely off the road at I75 ext 11 pilot truck stop The STUCK INJECT (already removed) - appears to be a Reliabuilt C65 with a D/D 390 number on it - He needs the part I've put him in touch with Greg Pagica ( http://www.cruiser-magazine.com/Help_assist_data_base.html ) - Anybody have an injector for him now OVER THE WEEKEND He can do the repair - he JUST NEEDS THE PART It's raining in Ga. - 4 guys in the bus - and a trailer full of Harleys Randy's cell# - ...262..498.7878... (Message edited by pete rts/daytona on February 28, 2009) |
Gary Pasternak (Cessna5354)
Registered Member Username: Cessna5354
Post Number: 59 Registered: 2-2007 Posted From: 72.90.9.251
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, March 01, 2009 - 7:00 am: | |
Pete it is great you are lending a hand here. I have a couple of questions, Does a stuck injector result in a loss in power ? Any other indications ? I also assume that cylinder exhaust would be cold as well, but I would never think to look at that initially, I would be thinking dirty fuel filters. Just trying to gain the knowledge that will assist me when I am in this situation. Thanks much and enjoy the rainy Sunday ( eastcoast). |
Post Number: 60 Registered: 2-2007 Posted From: 72.90.9.251
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, March 01, 2009 - 7:02 am: | |
Also thinking albeit slowly today, The oil sump will be collecting this additional fuel, not good either. Would this also be true? Thanks guys. |
Post Number: 534 Registered: 1-2005 Posted From: 97.104.13.172
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, March 01, 2009 - 8:57 am: | |
IIRC - when an Injector fails - many times it hold the rack open (full throttle) ??? I'm not sure - perhaps someone else can enlighten us ?? |
frankdegroot (Coach)
Registered Member Username: Coach
Post Number: 11 Registered: 1-2009 Posted From: 70.31.86.214
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, March 01, 2009 - 8:58 am: | |
Hi Pete, I have eight spare injectors for my 871.The # on them is 7E60 reliabit.If of any help let me know. coach |
Post Number: 535 Registered: 1-2005 Posted From: 97.104.13.172
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, March 01, 2009 - 9:10 am: | |
Hi All Randy has made it to Daytona - on his !!! 5V92TA !!! Pulled in at 3:00 AM Sat Morning - Then some SOB (ME) woke him at 9:AM to ask how he was doing (-: (-: I'll fire up my classic '87 VT1100 Shadow MotorCycle and We'll meet for breakfast Monday Morning - anyone else here in Daytona for Bike week ?? Pete RTS/Daytona P.S. Hey guys - We could sure use more members ( http://www.cruiser-magazine.com/Help_assist_data_base.html ) SIGN UP TODAY ( http://www.cruiser-magazine.com/Help_Assist_List.html It's certainly working SPECIAL THANKS TO DAVE & JAN SIEGAL - They are the force that keeps this list going |
Larry Nelson (Larryn4106)
Registered Member Username: Larryn4106
Post Number: 17 Registered: 8-2008 Posted From: 173.22.183.74
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, March 01, 2009 - 1:39 pm: | |
I had not even thought about carrying spare injectors. Sounds like it might be a good idea. Would one need to carry replacements for EACH injector (eight in my case)? |
Post Number: 1268 Registered: 5-2001 Posted From: 65.74.69.188
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, March 01, 2009 - 11:47 pm: | |
Just one would be a big help in most emergencies. Tom Caffrey PD4106-2576 Suncathcer Ketchikan, Alaska |
Post Number: 717 Registered: 10-2006 Posted From: 69.19.14.33
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, March 02, 2009 - 7:59 am: | |
THe other item needed will be the "pin" used to set the height of the injector. There are at least 2 , so get the proper unit for your engine. Only one injector is OK insurance , but a fist full of jumper tubing is also a good idea. FF |
Post Number: 12 Registered: 1-2009 Posted From: 70.31.86.214
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, March 02, 2009 - 4:24 pm: | |
What would you need the jumper tubing for? |
Post Number: 973 Registered: 12-2000 Posted From: 71.54.29.215
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, March 02, 2009 - 6:10 pm: | |
Fuel jumper tubing connects the injectors to the fuel supply. They are known to occasionally crack allowing diesel fuel into the oil. This is a "not good" situation. They can be changed easily after removing the valve cover. Jack PS: If Jake brakes are installed, they require different fuel jumpers (to clear the Jake Brakes) |
Post Number: 13 Registered: 1-2009 Posted From: 70.31.86.214
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, March 02, 2009 - 6:30 pm: | |
I will be carrying a handfull of those. coach |
Post Number: 656 Registered: 8-2006 Posted From: 74.32.92.133
Rating:  Votes: 1 (Vote!) | | Posted on Monday, March 02, 2009 - 6:37 pm: | |
Coach, you don't need a hand full change over to the new style with the o rings they never break,leak and can be used over and over not like the 1 time lines of old good luck |
