Peter (Sdibaja) (209.242.148.130)
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, July 30, 2002 - 8:45 am: | |
I had my 4905 serviced at a truck stop last week, and one more time they did not have a oil filter in stock. I had a spare, but a common spin on type would be much better. There are adapters for the older cars to use a spin on, is there such a thing for the 8v71? Peter |
FAST FRED (65.58.191.168)
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, July 30, 2002 - 9:21 am: | |
YES Your local NAPA or DD store should be able to get one , about $75 from DD lots cheaper in a truck store or NAPA. There worth the cost in engine wear as you can easily pre fill the spin on with lube oil & reduce the dry running time after the oil change. FAST FRED |
MRbus (152.163.188.227)
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, July 30, 2002 - 11:37 am: | |
Peter, Fred is right on with the NAPA scource, they have the adapter, and the number is B 1303, the dealer price is $55.00 here in Minnesota. I am sure that any reputable supplier of filters can also find one for you. If interested, the adapter also has a pipe plug that can be removed for the installation of a temp. sending unit. Gus Haag |
Jerry Nanson (Jerryn) (206.135.94.194)
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, July 30, 2002 - 6:06 pm: | |
Which filter would you then use if you have the B 1303 adapter on the 8V71 DD? |
FAST FRED (63.215.229.46)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, July 31, 2002 - 5:11 am: | |
I use the DD , they cost the same as the rest , and at least you know its OK. I worry about unbranded stuff like "Fleet Supply" ect. Have had great luck with Fram in many marine engines , so far. FAST FRED |
mrbus (64.12.96.235)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, July 31, 2002 - 9:52 am: | |
Jerry, Again, I agree with Fred, stay away from the price leader filters, there is no savings there. The Fram B-96 is a good match for the adapter, but any of the name brand filters will fit. Good Luck Gus Haag |
