mel4104 (208.181.100.14)
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, January 30, 2001 - 11:37 am: | |
has anyone tryed changing a6-71 to a 6v71 and what are the good and the bad to doing it as a fellow with a 4104 over cooked his engine and i have 6 6v71s that he can have one for free but he would like to know what he is getting into. also i drive a 4104 but i treat mine better thhan the wife of 43 years.ths for the help. i am at parksville british columbia 250 248 2766 or email to selaplante@bcsupernet.com |
Glenn Lewis (162.40.197.128)
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, January 30, 2001 - 11:57 am: | |
I have a '59 4104 w/ 6V71 and v730 auto. It runs like a hound after a cold biscuit on the highway, but it is a little wimpy up the mountains. When I bought the bus, it had the V71 (blown up) and a 4 speed. I put another V71 in, and the V730. I had to make a drive shaft and have the front fire wall cut to accept the larger diameter tranny. I also installed an air throttle and put new bushings in the link bars to located the rear end. New air bags also. About the only thing I need now is a front wheel driven speedo, and to rebuild the steering box.(too much slop). I have been told I can change to a dry air filter and turbo my V71, but I wonder if the hp difference would be worth the $? |
Al Baxter (209.252.244.75)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, February 17, 2001 - 6:54 pm: | |
You can't just turbo your V71 and have it last. A turbo 71 has different pistons and put out a lot more heat also I believe It timed different Al |
