Grant Thiessen (Busshawg)
Post Number: 39 Registered: 10-2007 Posted From: 206.45.93.160
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, August 25, 2008 - 3:16 pm: | |
This is probably a stupid question but here it goes. I have a 4 burner stove top. It's brand new, the manual is for a few different models. It says MOST stove tops are set up for natural gas but are convertable to propane. It says I need to change the orifice that is supplied. However there isn't a orfice supplied. the reguelator has both LP nad NG on it. Can I hook up and go? How do I know which orfice it has? What happens if I were to try it? |
James Robinson (Jjrbus)
Post Number: 153 Registered: 12-2000 Posted From: 68.242.95.175
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, August 25, 2008 - 3:32 pm: | |
What I would do in this situation is take the stovetop to an LP dealer, not like 7/11 where they fill tanks. But someone that does service, installations,ect. You can find dealers in the phone book. They can tell at a glance if it is the right or wrong one, if not they should have the right ones in stock. |
Post Number: 523 Registered: 8-2006 Posted From: 74.32.83.140
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, August 25, 2008 - 3:37 pm: | |
Stop by a lowes in the kitchen dept and read the manual on one of the gas cooktops or ranges it is a simple change no orifice change just a adjustment that was the way it was on a stove my daughter bought (Message edited by luvrbus on August 25, 2008) |
Jim Schrecengost (Schrec)
Registered Member Username: Schrec
Post Number: 82 Registered: 2-2007 Posted From: 24.2.127.94
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, August 25, 2008 - 4:57 pm: | |
I just installed one that sounds close to yours, I had to unscrew the regulator and turn it over so the lp was ablt to be read. Hope this helps Jim |
Keith Wood (Ft6)
Post Number: 28 Registered: 8-2008 Posted From: 71.198.253.223
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, August 25, 2008 - 6:08 pm: | |
If it's brand new, contact the mfr and talk to their tech support. Ask if there is a local factory-authorized repair place to take it to. If is has NO orifices, have them send the right ones. |
Post Number: 524 Registered: 8-2006 Posted From: 74.32.83.140
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, August 25, 2008 - 6:39 pm: | |
Grant, these are the instructions that came with a friends of mines cooktop remove the aluminium cap from the top of regulator turn the cap over it will have lp stamped on the inside replace cap. his had no orifice to change another model remove the brass cap remove the green plastic shaft from the cap till it pops out of the grooves turn the shaft over push back in to the cap replace cap check for leaks |
Post Number: 40 Registered: 10-2007 Posted From: 206.45.93.160
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, August 26, 2008 - 9:48 am: | |
Thanks a lot guys, once again you all have helped me. This building a bus has had quite the lessons along the way. I didn't have any luck with any of the dealers, seems like once it is sold your on your own. However I did get a hold of a service department that is mailing out what they believe is the proper conversion kit. They did say that this particular stove doesn't have a conversion kit listed. Thanks again. |
