John Thorwardson (John_thorwardson)
Registered Member Username: John_thorwardson
Post Number: 1 Registered: 8-2008 Posted From: 136.229.5.44
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, August 25, 2008 - 1:37 pm: | |
Looking for information on how the disengaging device is supposed to work and how it is activated on a 1951 GM TDH. Any info on wiring or diagrams would be greatly appreciated. |
Patrick levenson (Zubzub)
Post Number: 25 Registered: 5-2007 Posted From: 70.53.217.44
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, September 06, 2008 - 9:20 pm: | |
if this is the same as the reverse solenoid on a 4104 I can help....if that is the case the solenoid pushes an arm that then in conjunction with the movement from 1st (or neutral) tol 2nd engages reverse. Eleetricallly it's a solenoid, run current through it and it moves. How you get the current there is whatever. Use a relay or whatever to control it from the dash. This is vague but I'm not even sure of what you have a pic always help[s. |
Post Number: 551 Registered: 8-2006 Posted From: 207.231.75.253
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, September 07, 2008 - 4:18 pm: | |
Pat, T=Transit D=Diesel H=Hydramatic, so a stick reverse solenoid isn't the same thing. |
Post Number: 4 Registered: 8-2008 Posted From: 136.229.5.44
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, September 10, 2008 - 3:44 pm: | |
Thanks for the responses. I don't have a pic of what I have yet but on top of the tranny directly above the arm on the side that controls the forward/reverse function is an electically controled device that I believe engages/disengages some sort of clutch that allows the movement of forward/reverse with the engine running. I don't know what controls that device and or if it is functional. Troubleshooting with no documentation. Yippee! Thanks again for your resoponses. John |
