joe shelton (Littlewind) (67.241.228.33)
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, June 21, 2002 - 8:13 pm: | |
I am helping to replace the rear spindles on a 4106. We plan to cut (tourch) the old ones out while the new ones are cooling in dry-ice. Any one ever done this? Joe 4106-2119 |
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, June 21, 2002 - 8:25 pm: | |
Joe - Before you do this, I suggest you call Luke at US Coach (1-888-262-2434) and find out how to do it RIGHT, so it doesn't get screwed up! RJ PD4106-2784 Fresno CA |
lukeatuscoach (67.235.168.10)
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, June 21, 2002 - 8:38 pm: | |
Hi Joe: You don't mention why you are replacing the rear axle tubes????? If they must be changed, you might check in your Yellow Pages under Axle Repair. We have a company out here (N.J.) that comes in, cuts off the tubes, bevels the stubs and welds on a beveled replacement tube END with the proper threads and sized for the wheel bearings. I only mention this because his company is not unique but rather he & other companies all over the country have access to these replacement ends nationally. The first time I heard of it was about 20 years ago when a customer told me about it. I had my doubts, had the guy come in & do the repair and that bus parked on our lot & operated many miles per day in charter service. It made a believer out of me & we have had him make the same repair on many buses and never had a come-back. In my 40 years in the business, I never tried nor have I seen the tubes replaced as you described which is probably in Da Book. I don't know the possible pitfalls and only offer the above as a KNOWN SUCCESSFUL repair for the job you want to do. I Hope this HELPS!!!! And most importantly. HAPPY BUSSIN!!!! LUKE at US COACH |
joe shelton (Littlewind) (67.241.230.175)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, June 22, 2002 - 1:14 am: | |
That helps alot! We pulled the rear wheels cause of leaking seals. Found the RH tube had pretty big steps worn in it and the other side a little too. Already have the replacement the tubes but they can be returned. Luke's way sounds alot better. Thanks, Joe |
