don (Bottomacher)
Post Number: 167 Registered: 12-2000 Posted From: 72.15.86.59
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, May 30, 2008 - 7:14 pm: | |
Can someone please tell me what light is the third from the left on the bottom row of the MC9 cluster? It isn't marked and if it's in the book I can't find it. Thanks in advance Don |
JR Lynch (Njt5047)
Post Number: 252 Registered: 7-2006 Posted From: 70.61.104.58
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, May 31, 2008 - 9:38 am: | |
I believe it's 'check transmission.' If the second from the lower left is 'check engine', the trans light is immediately to the right on my 87. JR |
don (Bottomacher)
Post Number: 168 Registered: 12-2000 Posted From: 72.15.86.59
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, May 31, 2008 - 10:29 am: | |
JR, on mine, the second is the stop light. Is yours a DDEC? |
JR Lynch (Njt5047)
Post Number: 253 Registered: 7-2006 Posted From: 69.132.233.230
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, June 01, 2008 - 7:20 pm: | |
Yes. It is a DDEC. And the second is the check eng light. My brake light indicator is in the center of the second row. I've got an owners manual somewhere that shows the grid for an MUI. If no one has an answer for you I'll look for it and post what it says. JR |
don (Bottomacher)
Post Number: 172 Registered: 12-2000 Posted From: 72.15.86.59
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, June 01, 2008 - 9:01 pm: | |
I'm not sure what a mui is. I have the maintenance manual and parts book, but neither shows it. My bus is an 81. By the way, there is no writing on the lens for this hole, and all the others are clearly marked. Thanks Don |
Post Number: 457 Registered: 8-2006 Posted From: 207.231.75.253
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, June 02, 2008 - 1:20 am: | |
Don, Detroits are either Mechanical Unit Injectors, or electronically injected, DDEC. If there was no writing on the lens, it is a spare. I am assuming there are no bulbs hanging by their wires under there? Third from the left on the on the bottom row of a 6 is the A/C failure light, second over is blank. For what that's worth. George |
