james kennedy (Molases)
Registered Member Username: Molases
Post Number: 3 Registered: 10-2006 Posted From: 12.189.32.58
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, April 30, 2008 - 11:02 pm: | |
Sounds like my dryer is bad I however cannot shut the bus down, no air pressure?? |
ED Hackenbruch (Shadowman)
Post Number: 62 Registered: 11-2003 Posted From: 70.201.188.101
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, May 01, 2008 - 12:38 am: | |
You will have to do it manually at the back of the bus. I think there are some pictures posted here or on the other board that show the location of the valve if you do not know where it is or what it looks like. |
Post Number: 427 Registered: 8-2006 Posted From: 207.231.75.253
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, May 01, 2008 - 1:41 am: | |
Jim, All of the mechanical Detroits require air pressure to operate the shutdown lever. The cylinder is located in the middle of the Vee, only about three inches in from the "front" of the engine. If your bus has fast idle, the fast idle cylinder will have a tee in the air line, with one cylinder preventing the throttle linkage from moving, and the other is further down on the side of the governor. The stop cylinder, which has one air line, straight from the bulkhead, pushes on a small lever which stops the governor. You can push this lever easily with your thumb. The emergency stop button may or may not fully stop the engine. If you stopped the engine this way, you will have to re-latch the flapper, which is up on the side of the air intake, with a small cylinder with one wire connected to it. Hope this helps, and that you've already got the engine stopped! Regards, George |
Patrick levenson (Zubzub)
Post Number: 22 Registered: 5-2007 Posted From: 74.59.81.77
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, May 01, 2008 - 9:58 am: | |
just so's you know, all detroits may have started needing air pressure to shut down but some (at least mine) have been moded to need pressure release to shut down. the shut down rod(straight off the valve head) only closes the rack after the cylinder connecting it has been pressurized and then had the pressure released. I have no idea why it was set up this way just know that POs can do some crazy things...I think I may have the shut down system of some other diesel engine fit onto mine...if anyone recognizes what I"m talking about I'm all ears. (Message edited by zubzub on May 01, 2008) |
Post Number: 638 Registered: 11-2005 Posted From: 208.54.200.37
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, May 04, 2008 - 6:11 pm: | |
Patrick, If yours shuts down with pressure release how do you ever get it started when you have no air pressure?? |
Ralph Peters (Ralph_peters)
Registered Member Username: Ralph_peters
Post Number: 19 Registered: 12-2008 Posted From: 206.251.10.173
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, March 17, 2009 - 10:30 pm: | |
My 8-71ta used a 12V. soloid Not air to shutdown, was in a truck. But in the bus it will have air for shutdown. |
