Don Evans (67.227.207.247)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, April 24, 2002 - 12:39 pm: | |
We have a 120V in our current conversion and want a tankless system in the new conversion. Love those long hot showers! What brand and type? Standing pilot or electronic ignition? Any brands/model to stay away from? Installation tips? Thanks, Don E |
Lin (65.184.0.189)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, April 24, 2002 - 5:07 pm: | |
Ours is a Paloma unit. I do not know the specs on it and have seen bigger ones. I think Bosh makes one also that is available at Home Depot. If I were looking, I would compare specs with a particular eye on max flow. |
Lee Brady (Leeb11) (216.128.134.161)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, April 24, 2002 - 8:50 pm: | |
Ive got a Precision Temp RV-500. Its a tankless unit made for rv's. real easy to install.has a flow switch in it, so when you turn on the hot water you have hot water now. its get i might have to think about putting in bigger tanks ha ha. It has a electronic ignition and only weighs 27.5 pounds.I think its the best out there, but thats my opinion. There web site: www.precisiontemp.com Hope it helps Lee 66 01 |
Bill K. (209.173.112.238)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, April 24, 2002 - 10:16 pm: | |
I also used a Precisison Tem unit for coach and eng. and hot water. Heat. |
OAE Palmer (208.164.96.121)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, April 25, 2002 - 2:02 am: | |
Using the Bosch unit here Boss..! Installed it in a small Mfg. plant as a test before it went into the 4106. It supplied 2 sinks and a shower with all the HOT water in the world. At 5pm it got a 20 minute workout from the 5 employees, and never broke a sweat. Mine is a full time pilot, is all stainless inside and takes up about 3sq.ft. of WALL space, weight is about 12 lbs, and would work for 2 weeks under the above conditions on a 25# propane can. It was like buying a trust account, the front end cost was a lump in the throat,...ah! but a HOTEL shower everyday for over a year melted that lump away in nothing flat. |
