Phil Hendrix (Phil9tx)
Registered Member Username: Phil9tx
Post Number: 15 Registered: 8-2006 Posted From: 207.155.58.249
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, December 26, 2007 - 7:22 am: | |
In the cold weather my 6v92 weeps water. Where should I start tightening? It is really not evident! Except the puddle. I figure the heads, you pull the valve covers to tighten all I figure? No leak when warm! |
Rob Norgren (Robsedona)
Post Number: 27 Registered: 11-2007 Posted From: 75.211.17.65
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, December 26, 2007 - 8:10 am: | |
I would Start at all the rubber hoses! that is where Mine started to leek in the cold weather :-) after they where tight all was fine. and yes Mine was fine in the warm weather I figure the rubber and metal expanded different. |
Donn Reeves (Donnreeves)
Registered Member Username: Donnreeves
Post Number: 16 Registered: 3-2007 Posted From: 69.115.65.240
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, December 26, 2007 - 8:27 am: | |
I would take a look at the slobber tubes. If antifreeze is leaking from them when cold it would indicate seepage past the cylinder o-rings. Don't waste your time checking head bolts. The water passages are seeled with o-rings and rarely leak unless installed wrong. Donn |
Post Number: 79 Registered: 10-2006 Posted From: 71.239.202.82
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, December 26, 2007 - 7:08 pm: | |
Now is also a good time to run down the smaller air leaks. You will find the smaller ones quicker and easier in the cold. Be sure to check around your heater core too, many hose clamps there. |
Post Number: 566 Registered: 11-2005 Posted From: 206.40.238.187
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, December 27, 2007 - 3:57 pm: | |
My 671 does the same thing but only after the weather has been cold a day or two. The reason is that DDs are huge chunks of metal hear sink. After they get good and cold they sweat huge amounts of water the first time the weather warms up and/or gets humid. |
Post Number: 234 Registered: 2-2001 Posted From: 208.6.60.4
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, December 27, 2007 - 4:38 pm: | |
Now you realize what that protective insulating grease coating is for! I bet it's only the clean engines that sweat. Jim-Bob |
Cindy and John (Cindyandjohn)
Registered Member Username: Cindyandjohn
Post Number: 54 Registered: 1-2007 Posted From: 70.15.55.179
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, December 27, 2007 - 4:52 pm: | |
I would check all hoses... is it water or anti-freeze? my silicone hoses seep anti-freeze when it gets real cold - so i go around and re-tighten all clamps. I am in the process of changing all old style clamps to the constant compression type. they are more expensive but work much better. Hope this helps... John |
