Simon Ayriss (Design_dog)
Registered Member Username: Design_dog
Post Number: 75 Registered: 3-2007 Posted From: 69.227.189.77
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, December 24, 2007 - 4:04 am: | |
I'm sure it's been brought up before. I looked through the archives a bit. Maybe someone can point me in the right direction. I need to replace my MC8 leaky marker lights. I don't think I want to do any major modifications for the lights. The originals are fine. Should I just order these from MCI or where is the best place to get them? Any tips on the wiring? Are there any LED replacements or alternatives that actually fit right in and don't require major rewiring? Thanks. |
David (Davidinwilmnc)
Registered Member Username: Davidinwilmnc
Post Number: 216 Registered: 7-2005 Posted From: 75.180.200.138
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, December 24, 2007 - 9:59 am: | |
Mine were leaky too. I think people would be surprised at how many leaks actually come from the marker lights! I got mine from Luke. I think they were about $16 each, but it's been a couple of years. Just cut off the old connector and crimp on a new one. I also added a bit of silicone sealer behind each one... just to make sure there's no more leaking. Also, they will leak between the lens and the light itself, so I sealed between the lens and light on some that didn't seem to fit as well as others. I eventually replaced all of them, as the bases had hardened and wouldn't seal well. David |
Registered Member Username: Chucks
Post Number: 1187 Registered: 10-2003 Posted From: 70.3.75.221
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, December 24, 2007 - 5:01 pm: | |
I too just replaced the originals. I know the hoss's on the board do LEDs, but I couldn't see going to the trouble. If I could have found some direct swap LEDs I probably would have done it. So, Mohawk to the rescue! ----------- Mohawk Clearance Lamps; part numbers 7R-7-98; 7R-7-105; and 7R-7-107 • Mohawk lamps have been retooled for improved durability and a better defense against wet weather. • Lens and body made using automotive-grade polycarbonate resins for high strength and heat resistive properties. • Come furnished with a 624 bulb, producing 6 candle power at 28 volts. • Manufactured and assembled in the United States. 7R-7-98 (Red) comes with 7R-7-80 lens. 7R-7-105 (Amber) comes with 7R-7-79 lens. 7R-7-107 (clear) comes with
7R-7-108 lens. Mohawk Price $10.81 ------------------ I sealed betwn the gasket and the roof as well as the lens and the gasket, like David. I used Lexel. (cool stuff) Direct swap out, new gasket and lamp included, couldn't have been easier. |
JR Lynch (Njt5047)
Post Number: 201 Registered: 7-2006 Posted From: 69.132.233.230
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, January 06, 2008 - 9:49 pm: | |
What's "Lexel"? Some sort of sealer? I sealed my new clearance lights with silicone based high-tech stuff and I believe they still leak. Gotta carry this sealing thing one step further. I'd pull the bus out into the rain, but it's all clean now. Not about to nasty it up in the winter. Maybe a garden hose would show the problem. Something's leaking over my dash. Doesn't leak sitting still, just when driving at speed. Then look out! Thanks, JR |
Post Number: 1152 Registered: 12-2000 Posted From: 76.68.132.4
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, January 06, 2008 - 11:47 pm: | |
Water driven past the windshield seals? You wouldn't believe where it will seep through when under way. happy coaching! buswarrior |
Post Number: 95 Registered: 3-2007 Posted From: 69.227.189.77
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, January 15, 2008 - 4:00 am: | |
I think it's common up front to leak at the front cap and in the middle windshield seal. A lot of leaks fall down near above the center windshield beam. The problem is the "higher" up you get any minor leak, like in the marker light or even above... the worse it is because then it leaks down into the walls and it could leak around the windows. Like the side windows. It looks like a side window leak but it could be coming from anywhere. I would be interested in Lexel or any other way of stopping leaks. I have to at minimum do a hose check at least once and maybe with a air line. Unfortunately leaks can be a big problem looks like. |
