Doug in FL (199.250.20.136)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, April 10, 2002 - 12:33 pm: | |
Is there a way of converting existing bay door system on GM 4501 from rubber hinge, causing door to have to swing out and up to open, to a more straight up parrell with bus using cylinder type support, found on newer buses? Thinking about it I could probably only covert the top door and keep bottom door like it is, since mine has a 2-door system with bottom latching. Thanks for all the info I have collected! |
