Post Number: 108 Registered: 3-2007 Posted From: 76.4.149.200
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, October 28, 2007 - 6:40 pm: | |
dennis, I have used pressure treated plywood on a lot of under=carriage work with good results. you may get and put 2 layers together to compensate for the thickness. about supports, I have used just strapping from a salvage yard and when needed just weld together if necessary. avoid bolts as they may rub a hole in the tank, and all the do is keep the tank secure. that all folks Gomer |
