Ed Roelle (Ed_roelle)
Registered Member Username: Ed_roelle
Post Number: 39 Registered: 3-2005 Posted From: 68.85.142.109
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, October 02, 2007 - 12:08 pm: | |
You still have a major alignment problem. As quick as your tire is wearing, you may have either loose, worn, or bent components. You can check for the worn components by jacking the bus and wheel and looking for relative movements. You can also do a rough alignment check, but I would expect wear in the brass bushing or tube. Ed Roelle Flint, MI |
