doug yes (Dougg)
Post Number: 37 Registered: 1-2007 Posted From: 71.30.225.176
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, September 20, 2007 - 11:17 pm: | |
JohnMC9 mentioned you had one of these. Does it work well? Is it a package unit or is it belt driven off the bus engine? |
Post Number: 511 Registered: 7-2006 Posted From: 66.217.107.114
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, September 21, 2007 - 12:00 am: | |
Doug - The Welch Auxiliary system runs with a belt from the engine, the same as an automotive AC system. They have both a 12 and 24 volt version. (You can also find these units used, and fairly cheap). My MC9 came with one; it'll put ice on the windows, if I run it on high. Aside from the blower noise typical for that type of air conditioning when on high (it's like a massive window unit), it's a pleasure to own. Because it's located in the rear, it fails to cool the driver's area on a real hot Florida day, but some owners have piped it into the dashboard system, and fared well with it. The Welch Rep I talked to can give a name or two to contact, but they did not supply the "how to" info directly (it was awhile ago, perhaps their policy have changed?). Keep in mind, that a basement AC system's cost may be comparable, and the benefits better! I chose to use rooftop AC's, for both price and repair/replacement factors, and keep the Welch as a backup and additional cooling.... There's no "right or wrong", it's all a matter of how you plan to use your rig, and how much you want to spend. (I'm a cheap %$^#). |
Gene Lewis (Genelewis)
Registered Member Username: Genelewis
Post Number: 72 Registered: 12-2000 Posted From: 71.50.133.2
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, September 21, 2007 - 6:19 am: | |
If I were interested in a used unit where should I start looking? |
Post Number: 161 Registered: 8-2004 Posted From: 209.60.120.130
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, September 21, 2007 - 9:04 am: | |
Gene Lewis wrote: "If I were interested in a used unit where should I start looking?" __. I did an EB*y search and Googled. No luck. |
Post Number: 513 Registered: 7-2006 Posted From: 66.217.107.204
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, September 21, 2007 - 9:59 am: | |
Google this: Used bus parts Or Surplus bus parts There are plenty of bus junk yards around, and many local bus operators with buses they're parting out.... I'd try calling some local bus operators, and ask. If they don't have a junk bus, they may be able to tell you where they sent it.. Keep in mind, that although the Welch system is great for using while the engine's running, there are other alternatives that may be more useful to you. A high output diesel genset can run AC units, heaters, and all the other toys that can be run from the power-pole also. |
Post Number: 162 Registered: 8-2004 Posted From: 209.60.120.130
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, September 21, 2007 - 10:36 am: | |
John MC9 wrote: "the Welch system is great for using while the engine's running" Is it practical to convert this system to an electric motor-driven compressor? I'm thinking run the compressor off engine alternator (or gennie) while underway and pole (or gennie) while parked. I recognize that we're talking serious amps here but it should be do-able with the right parts. |
bill chisholm (Billybandman)
Registered Member Username: Billybandman
Post Number: 122 Registered: 2-2001 Posted From: 198.236.64.24
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, September 21, 2007 - 7:21 pm: | |
I have a used Carrier that came from a Airporter that is very similar to the Welch. See the Flea Market, June 28th |
Post Number: 514 Registered: 7-2006 Posted From: 66.217.101.54
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, September 21, 2007 - 8:17 pm: | |
The Welch rep told me that it's not likely to be able to run the AC compressor on any "practical sized" electric motor. Ahhh..... anything is possible.... but practical? There's so many options, why beat a path through the swamp? The Welch is a great system to use in place of the OE system, and along with a basement system, split, or rooftop units... And it's possible to pipe it into the existing dashboard system.. It is, only what it is. |
