John G Root Jr (Johnroot)
Registered Member Username: Johnroot
Post Number: 91 Registered: 2-2002 Posted From: 64.214.182.176
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, September 12, 2007 - 7:18 pm: | |
I went to start my bus - a 4106 - and the buzzer doesn't come on. There is power to the switch (the middle terminal registers 12.58 volts). When I turn the switch to day there is no longer power to the middle terminal and no power to the post at the bottom of the compartmaent that comes from the start batteries. The head lights don't come on, the flasher ticks but the turn signals don't light. Where should I start looking for the short? Any thoughts would be appreciated, I was planning to go to the beach in North Carolina from Mass on Friday, oh well! |
Frank Allen (Frank66)
Registered Member Username: Frank66
Post Number: 59 Registered: 10-2005 Posted From: 207.200.116.13
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, September 12, 2007 - 8:15 pm: | |
id clean the terminals real well before i did anything, could just be a poor connection Frank Allen |
Laryn Christley (Barn_owl)
Post Number: 77 Registered: 10-2006 Posted From: 153.2.247.30
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, September 12, 2007 - 8:23 pm: | |
Are you sure you have a short? Are you tripping the breakers? It sounds like an open or a poor connection to me. If you are running out of time, just rig up a few toggle switches and repair the rotary switch when you get back. If you think it is the switch you can take it apart and inspect it if you are careful and don’t loose the small stuff. |
Post Number: 78 Registered: 10-2006 Posted From: 153.2.247.30
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, September 12, 2007 - 8:26 pm: | |
After reading your post a little better, I would check the battery connections and work my way forward. |
Post Number: 92 Registered: 2-2002 Posted From: 64.214.182.176
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, September 13, 2007 - 10:20 am: | |
Thank you guys,I'm looking for a bad ground! Wish me luck! Thanks, John |
Post Number: 93 Registered: 2-2002 Posted From: 64.214.182.176
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, September 13, 2007 - 11:10 am: | |
