Buddy Tennison (Buddyten)
Post Number: 38 Registered: 7-2005 Posted From: 207.68.234.24
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, August 16, 2007 - 12:03 am: | |
We are planning on installing a retrofit ceiling in our Eagle, using .90 thick fiberglass panels attached to 1" wide stripping (1/2" thick) between which we will apply the 1/2" thick insul board. I want to use a very good adhesive to fasten the panels to the stripping that will allow me to minimize the use of fasteners, etc. I have seen you all speak so highly of Sikaflex, and have looked at the usual Lowes, HD, etc but have not found it (at least under that brand name). Can anyone give me info on where I can get it, or if there is another generic name, etc. Also your opinions on the application I plan to use it on. Thanks for the help. |
steve gaines (Kysteve)
Post Number: 113 Registered: 12-2006 Posted From: 74.140.165.225
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, August 16, 2007 - 5:53 am: | |
Buddy, International Bus and Parts in apopka florida has it and since they seem to use or sell alot of it and it has a short shelf life they are probably your best bet. hth ...Steve... phone # for them, 800-468-5287 (Message edited by kysteve on August 16, 2007) |
Post Number: 199 Registered: 7-2006 Posted From: 4.240.213.14
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, August 16, 2007 - 10:34 am: | |
www.austinhardware.com FWIW RCB |
Bob Shafer (Michigander_bob)
Registered Member Username: Michigander_bob
Post Number: 37 Registered: 2-2005 Posted From: 68.61.134.126
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, August 16, 2007 - 2:37 pm: | |
you might want to give this stuff a try if you can find it at a local roofing supplier (not HD or lowes)I use a lot of it on my bus and it works great. around $8.00 a tube. http://www.bestmaterials.com/detail.aspx?ID=14958 Bob 4104-2346 |
