carl white (Carl_mci_9)
Registered Member Username: Carl_mci_9
Post Number: 18 Registered: 1-2007 Posted From: 208.108.101.210
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, May 30, 2007 - 1:15 pm: | |
I am trying to remove the front cam bearing on my 8v71. The first one came off with little trouble the second one I cann't move it at all. The triangle bearing holder is to close to the block to get a traditional wheel\bearing puller under it to get it off. Has anyone had this problem and how did you finaaly get it removed Thanks Carl |
larry currier (Larryc)
Post Number: 111 Registered: 2-2007 Posted From: 64.12.116.203
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, May 30, 2007 - 11:26 pm: | |
I think you need a special tool. It will allow you to remove the bearings and also install the new ones. I don't think you can do the work without the tool. |
guy bouchard (Guy_bouchard)
Registered Member Username: Guy_bouchard
Post Number: 9 Registered: 11-2004 Posted From: 161.184.179.138
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, May 30, 2007 - 11:45 pm: | |
There should be no special tool needed. I assume you are having trouble with the dry bearing (opposite water pump). There is a gasket behind that bearing and it was probably glued down on both sides. If you look closely you will see some little notches midway between the bolt holes. A little crowfoot bar and GENTLE tapping should get it moving. Good luck Guy 4905 |
