Post Number: 40 Registered: 3-2007 Posted From: 76.198.86.113
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, May 10, 2007 - 12:30 pm: | |
Anyone used the Steer SafeŽ on your bus? Does anyone know the steering manufacturer? Rockwell? I contacted the Steer SafeŽ toll-free number and they said they'd have to know the steering manufacturer to know if they can fit it. Alternative steering damper systems? Thanks, dg |
J.C.B. (Eagle)
Registered Member Username: Eagle
Post Number: 112 Registered: 12-2000 Posted From: 74.130.33.78
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, May 10, 2007 - 12:56 pm: | |
DG I have the Safe-T-plus installed on my model 10 Eagle. Safe-T-Plus.com |
Richard D. Bishop (Rdbishop)
Registered Member Username: Rdbishop
Post Number: 12 Registered: 1-2007 Posted From: 70.124.123.157
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, May 10, 2007 - 9:59 pm: | |
J.C.B. How do you like the Safe-T-Plus and does it handle compared to before you had it. rdbishop |
Jim and Myrna Lawrence (Daffycanuck)
Registered Member Username: Daffycanuck
Post Number: 36 Registered: 10-2004 Posted From: 66.82.9.52
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, May 11, 2007 - 1:11 am: | |
DG I had the Safe-T-Plus installed after a Bus Conversion friend lost his life in a crash caused by a blowout. I give credit to the Safe-T-Plus "blue" product in saving us from a crash when on a curve, the wind pushed me over the 8" edge drop of a Mexican highway. Power steering is a requirement and I don't notice any difference in normal driving. I recommend putting it on your vehicle and hope it never has to prove it works!! |
J.C.B. (Eagle)
Post Number: 113 Registered: 12-2000 Posted From: 74.130.33.78
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, May 11, 2007 - 8:10 am: | |
Before I had it installed the coach would drift one way or the other but with the Safe-T-Plus it tracks in a straight line. It was very simple to install on the Model 10 Eagle. |
James Smith (Tomcat)
Registered Member Username: Tomcat
Post Number: 35 Registered: 8-2005 Posted From: 207.200.116.13
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, May 11, 2007 - 9:48 am: | |
I installed a Steer Safe on my 87 Thomas SaftLiner. I found it made a great difference. It takes a lot of the 'work' out of driving as it keeps the coach moving in a straight line until you're ready to change it's path. My coach does have a Rockwell axle. Quick install too. About an hour. Jay 87 SaftLiner (Message edited by tomcat on May 11, 2007) |
Post Number: 320 Registered: 7-2006 Posted From: 66.217.105.196
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, May 11, 2007 - 11:16 pm: | |
Want another opinion? We had the "Steer-Safe" spring units on a 33' Winnebago... After replacing the front tires three times in four years, along with the customary and expensive wheel alignments trying to cure the "problem"..... and after having the unit's springs reset to the proper tension..... the damned RV tires were still wearing weird (edge wear; cupping, etc). It ended up being one spring that had lost some of it's strength. It was the proper length, and set to the proper tension, but didn't fare well with usage. Having to replace tires prematurely was a nice way to learn what happens when the things go sour.... The RV shop showed me how those hydraulic cylinder units work... Nice! Especially when the engine stalls leaving the driver to not only have to fight the non-working power steering, but also having to fight the extra hydraulic cylinder. It's like a shock absorber connected to the steer linkage. Oh yeah, and trying one out was a swell experience too! Before installation, the steering was quick and sure. After installation, the steering wasn't too quick at all; sluggish, is a word I'd use... The power steering had to fight the "shock absorber"! Of course, that was on "stick N' staple" RVs, not an expensive, "built for commercial use" bus... Does make me wonder why they'd be needed on a bus, though.. It sure would seem like the $400-$800 that the units cost, would be better spent on needed front end work.... If the bus is pulling, or not handling properly, adding an after market device to hide the problem, just doesn't sound like the greatest idea..... (just -my- opinion, ya' unnerstan...) |
Post Number: 521 Registered: 10-2004 Posted From: 70.220.134.1
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, May 12, 2007 - 12:02 am: | |
I was always led to believe that the steer safe was in case you had a front tire blow out! It would keep the vehicle from dashing out from under you so to speak! Wasn't my ole buddy Gene Rochester one of the original testers of this unit before it was marketed? I remember him telling me that he used to have a prototype unit installed on one of his racing semi trucks and it had charges mounted on the truck that would make a front tire blow out on purpose, during development of course! I think on some of the newer Prevost they come standard now too! Ace |
