RJmule (Rjmule)
Registered Member Username: Rjmule
Post Number: 78 Registered: 2-2007 Posted From: 75.51.71.238
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, May 08, 2007 - 12:49 am: | |
could anyone send me in the right direction for a generator head that will bolt up to my kubota D850 Diesel engine,It came out of a portable light tower; Thank You . RJmule Randall |
Post Number: 772 Registered: 5-2005 Posted From: 72.189.203.211
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, May 08, 2007 - 8:12 am: | |
You might look at a head from Marathon Electric, The light-plant Pancake heads with the right housing adapter should be available. http://www.marathonelectric.com The other supplier that makes adaptable heads is Marelli ( Italian ) and they have a U.S. distributor. http://www.marellimotori.com The bell housing sizes are on Kubota's engine website and the adapter listings are on Marathon's website. If that engine came off a light plant, what happened to the gen head? They are rebuildable quite reasonably. Dave.... |
Post Number: 1891 Registered: 1-2001 Posted From: 75.108.86.176
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, May 08, 2007 - 10:25 am: | |
As I recall, you are in the Southern California area. If so, try and find Nim's generator repair in the old 714 area code area. It has been 10 years since I have been there, but if he is still in business he can help you. Richard |
