Doug Ritter (Texrbama)
Registered Member Username: Texrbama
Post Number: 12 Registered: 3-2007 Posted From: 72.146.235.4
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, March 25, 2007 - 7:15 pm: | |
Which is the auxillary air tank on a 72 Eagle |
Bob greenwood (Bob_greenwood)
Post Number: 781 Registered: 7-2006 Posted From: 64.136.49.228
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, March 25, 2007 - 11:21 pm: | |
what do you mean.....you have 5 air tanks on your Eagle....what do you want to know ??? |
Post Number: 782 Registered: 7-2006 Posted From: 64.136.49.228
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, March 25, 2007 - 11:23 pm: | |
larry currier (Larryc)
Post Number: 68 Registered: 2-2007 Posted From: 207.200.116.13
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, March 25, 2007 - 11:51 pm: | |
I guess you could consider any air tank after the wet tank an auxillary. If you want to run air tools, pick the largest tank you have, that is usually the one between the steer tires on an Eagle. |
Post Number: 13 Registered: 3-2007 Posted From: 72.146.235.4
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, March 26, 2007 - 10:07 am: | |
Sorry guys, what I'm wanting to do is disconnect the old air line to the old air assist clunch system. I may have a small air leak under the floor that is so hard to get at. The coach has a auto tran and so of the auxillary items are not in use anymore such as the A/C, Restroom and the cluching system which pulled air off this tank. If I can locate the correct tank, I will solve a big concern. |
Mark Renner (Boomer)
Post Number: 51 Registered: 11-2006 Posted From: 12.180.53.193
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, March 26, 2007 - 5:27 pm: | |
The aux. tank is the farthest one forward, located between and just a little forward of the front wheels. Also supplies the door and windshield wipers if you still have air ones. |
Post Number: 14 Registered: 3-2007 Posted From: 72.146.235.4
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, March 27, 2007 - 7:46 pm: | |
Thanks, I was thought maybe towards the back of the coach. I will do my home work before disconnecting any air lines. We will be making a run from Florida back to Connecticut this week. Worked all week on doing preventive/corrective maintenance. Thanks again Bus Nuts for all the support. |
Post Number: 789 Registered: 7-2006 Posted From: 64.136.49.228
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, March 27, 2007 - 10:07 pm: | |
find the line you want to eliminate and buy a 1/4 plug for the tank |
