T. (Bluegrass)
Registered Member Username: Bluegrass
Post Number: 222 Registered: 4-2002 Posted From: 72.160.128.210
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, December 09, 2006 - 12:39 pm: | |
I have a Wrico Genset 8.5 and a remote switch that I took off the other coach and I did the wrong thing when i took it off, my question how do I wire a remote switch for this unit. |
Post Number: 1767 Registered: 1-2001 Posted From: 75.108.82.163
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, December 09, 2006 - 2:12 pm: | |
I would suggest you contact Dick Wright, directly at WRICO: http://www.generatorman.com/ In general, the remote start stop switch is wired in parallel with the unit mounted start stop switch. Richard |
Kyle Pesely (Kylexisxrad)
Registered Member Username: Kylexisxrad
Post Number: 91 Registered: 12-2005 Posted From: 67.169.239.5
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, December 09, 2006 - 5:22 pm: | |
i concur. i have a Wrico 8KW in my Eagle and ive called Dick numerous times with lots of different questions, and he(and his staff) are always helpful and really know their product well. kyle in norcal 1980 Eagle 10 #30223 |
Post Number: 396 Registered: 10-2004 Posted From: 75.201.13.2
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, December 09, 2006 - 7:30 pm: | |
Bluegrass what exactly did you do wrong? Did you not label the wires or something? I have a manual that tells what goes where but mine is a wrico 12.5kw. It might be the same but not sure. I have a remote starter inside the bus if that's what your trying to do! The remote panel camed from Dick at Wrico! Let me know if I can help you with what I have or like others have said, give him a call and he'll be sure to guide you! Ace |
Post Number: 62 Registered: 10-2006 Posted From: 4.235.200.127
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, December 10, 2006 - 4:47 am: | |
A remote switch is nice , if and when it works, and you have the Knowledge to troubble shoot it when it fails. A simpler method that does not fail is two sockets (one SHORE one NOISEMAKER)with the COACH hooked to a plug. A bit more work switching , but fewer hassles with inverters and batt chargers dieing. Blue Bird mounted the setup in the rear of a hanging locker , out of sight but handy enough. FAST FRED |
Post Number: 1768 Registered: 1-2001 Posted From: 75.108.82.163
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, December 10, 2006 - 10:32 am: | |
FF, now you have me thinking, and thats a problem. LOL Although Bluegrass stated he wanted information on a remote start stop switch, maybe he really meant an automatic transfer switch. In that case, your recommendation is fine. If it is only to start stop the genset then the remote start stop switch is generally pretty fool proof. A three position toggle switch and three control wires from the remote switch to the genset switch. Richard |
