FAST FRED (209.26.87.54)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, January 05, 2002 - 5:23 pm: | |
Although ducting is a geat idea , you might get away with out some . We use the orig 06 condenser compartment as the Dual basement bay. The delivery air , all of it , blows up under the table in the main salon. It blasts up to the overhead , if the table leaves are closed. The coach is most likely to be used foward , either driving , or coolkin eating , sitting arround , during the day. The daytime is the time you need max AC as the insolation is so high . In the evening , with the sun down , cooling loads , even if its hot , is easy,,one unit. WE only use about 10 ft of the floor duct , but in a reverse manner. The floor duct is connected to the cieling return from as high as is practical & easy to hide . This recirculates the air , and you MUST , as an AC may only cool the air 15 deg on a pass, if its 105 and the sun is out , you will definatly want a couple of air passes. With stock windows and stock insulation , having the 2 units blow only foward , the max air avil is where its needed durin daylight And as the air delivery ,AC unit and return are foward , less noise comes back to the sleeping area , when not too much cool is needed. FAST FRED |
