Pin striping removal? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » August 2006 » Pin striping removal? « Previous Next »
  ClosedClosed: New threads not accepted on this page
  Thread Last Poster Posts Pages Last Post
Pin stripiiing removal =answerMel La Plante3 1 8-04-06  10:06 am
Mel La Plante (Mel_4104)
Username: Mel_4104
Post Number: 3
Posted From: 208.181.100.41
Posted on Tuesday, August 01, 2006 - 3:09 pm:
The question that i have is how do you get the pin striong off without ruining the paint under neith? this is on a 4104 and they put the striping on the top and on each side of the fluting and each colour is about 3/16 in. wide and it the good old stuff and just loves the bus and will not let go. thanks for any help. mel 4104
Roderick W. Chandler (Rod)
Username: Rod
Post Number: 17
Posted From: 69.30.188.192
Posted on Tuesday, August 01, 2006 - 3:30 pm:
Usually WD40 will make most adhesives turn loose. Spray and let soak for 30-40 minutes. Won't help with painted pin stripes.
Rod
Henry 96A3 (Hank)
Username: Hank
Post Number: 53
Posted From: 66.222.48.107
Posted on Tuesday, August 01, 2006 - 5:37 pm:
Mel,
I'm working on removing the charter coach lettering from my bus as we speak. I found this article to be very helpful: http://signweb.com/index.php/channel/1/id/28
Good luck!
Hank
Robert Wies (Ncbob)
Username: Ncbob
Post Number: 180
Posted From: 70.109.31.201
Posted on Tuesday, August 01, 2006 - 6:45 pm:
A heat gun or the wife's hair dryer, used sparingly
will certainly help. Use it in a 'test' area and see if it won't make your life easier. Cheers,
Bob
Steve N. (N4rsn)
Username: N4rsn
Post Number: 92
Posted From: 64.149.213.167
Posted on Tuesday, August 01, 2006 - 8:28 pm:
If the graphics are painted on, you can spray some ez-off oven cleaner in the graphics, and it will curl the paint up, and leave the factory paint. Do a small area at a time. Worked great for me, as the whole side of mine had a BIG name on it. Took it off.
My 2 cants
Steve
Bill K
Unregistered guest
Posted From: 71.31.76.65
Posted on Tuesday, August 01, 2006 - 8:48 pm:
They make a rubber eraser that you use in a drill. Works good, I got mine from the local auto parts store.
Username: Oonrahnjay
Post Number: 115
Posted From: 69.143.50.201
Posted on Wednesday, August 02, 2006 - 10:08 pm:
One of the problems with a pinstripe is that they're so thin that they tend to break as you pull them off. But the info already given will help you.
Tim (Bigtim44)
Username: Bigtim44
Post Number: 4
Posted From: 67.190.115.174
Posted on Thursday, August 03, 2006 - 10:18 am:
I've had great success with a strong pressure washer,the actual pinstipe will come off quickly,then go over the adhesive residue with laquer thinners or something similar.
Tim
Bob greenwood (Bob_greenwood)
Username: Bob_greenwood
Post Number: 43
Posted From: 63.233.41.179
Posted on Thursday, August 03, 2006 - 1:24 pm:
everybody keeps telling him how to take off decals.I think his are painted on. there is no way to do it,let me explain,if the stripe was painted on,it swelled the paint that was the original surface,so, if yo just sand it down till it disapers,it will still show . 40 (fourty) years of paint & bodywork.
Bryce Gaston (Busted_knuckle)
Username: Busted_knuckle
Post Number: 263
Posted From: 72.155.194.33
Posted on Wednesday, August 16, 2006 - 5:37 pm:
If they are painted on pin stripes I agree with Steve (n4rsn) EZ-OFF does an awesome job ! I've used it on buses, custom painted & lettered race cars, Tow trucks and etc. work a small area at a time an it comes off while leaving the base paint nice and shiney! BK
