dana Unregistered guest Posted From: 207.160.4.148
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, July 10, 2006 - 3:39 pm: | |
I have a 79 international with big block, thats all i know, where can i find out the motor, tranny and all other specs on this thing? I have hit the search button endless times with no luck. Thank you in advance. |
Bob Greenwood Unregistered guest Posted From: 63.233.105.209
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, July 10, 2006 - 5:35 pm: | |
look on the side of the bus & see what school it came from,go to their service garage & see if they have any service manuals on it |
Ed Jewett (Kristinsgrandpa)
Post Number: 249 Registered: 2-2003 Posted From: 64.24.212.106
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, July 10, 2006 - 9:39 pm: | |
There should be a decal somewhere under the hood(engine compartment). Also check with International, they may have only put one size in school buses that year. After 27 years the school that bought it may have moved away. (The school I went to moved 6 miles away) |
jimmci9 #2 Unregistered guest Posted From: 172.162.126.88
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, July 11, 2006 - 5:34 pm: | |
ihc used a 345 v8 and a 392 v8 gas engine... its hard to tell them apart as either can be a bbl or a 2bbl carbuerator....ihc also made a huge 549 cu in v8... but ive never seen it in a bus, only a straight truck.... |
James Y. Gochnauer (Jimgohio)
Registered Member Username: Jimgohio
Post Number: 2 Registered: 4-2001 Posted From: 64.0.112.152
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, September 05, 2006 - 12:45 am: | |
The Dodge semi trucks the company I worked for 30 years ago had 3 semi's with gas engines. They were International 478 ci and 549 ci. I can even tell you the truck nombers (but what good would that do?) When we got a GMC single axle semi- tractor with a 671, we really had a truck then. Jim g. - 1979 RTS-II |
