Jerry @ nc
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, January 11, 2006 - 7:27 pm: | |
What is the best way to do this I need to have some work done on my 740 It leaks oil when cold and in reverse (a lot)., in forward I do not see any leakage. but I can not see where it is coming from. |
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, January 11, 2006 - 7:39 pm: | |
Check the back-up light switch on the transmission. It is a pressure switch activated when the reverse circuit is pressurized. I have seen several of these switches fail. Thay are accessible from the outside of the transmission on the drivers side, just above the pan. Hope this helps, Jack |
Jerry@nc
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, January 12, 2006 - 1:21 pm: | |
Jack would this not leak when it was hot to. this only leaks when it is cold and in reverse Jerry |
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, January 12, 2006 - 6:12 pm: | |
Probably, unless reverse circiut carries a higher pressure when cold. What make and model of bus? If MCI, you can see this switch from the drivers side engine compartment door. Or clean switch and area around it, start engine, put in reverse, shut off engine and inspect the area around the switch. This will confirm or rule out the switch as the possible cause of your leak. Hope this helps, Jack |
Jerry @NC
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, January 12, 2006 - 9:21 pm: | |
Thanks Jack I will look at this, this weekend Jerry. My bus is a 102a3 and the the new years party was great look forward to next year |
