Tony Richardson (206.133.68.206)
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, October 23, 2001 - 5:06 pm: | |
I need U bolts and a pump to put sheepard steering on an 04. I have seen Nimco menchined. Can someone tell me how I can contact them and anyone else who might have parts. Thank you Tony |
Craig S (65.202.123.254)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, October 24, 2001 - 7:55 am: | |
Try this NIMCO/ Bus Division P.O. Box 5157 Newark, NJ 07195 (800)526-8055 (973)589-9265 (973)589-2253 Fax www.nimcobus.com Good luck |
mel la plante (208.181.100.23)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, October 24, 2001 - 11:41 am: | |
hi tom, i put a shepard steering unit on my o4, it came of a transit gm5306 and i used the same u bolts just put on new nuts. the big thing is to where you are going to mount the pump, i put mine on the end of the blower shaft and this required a little bit of machining and welding to be able to adapt the pump to the engine, you will need a extended blower shaft,retainer clip,the drive unit out of a v6 complete fith the fiber drive coupler, then make a spacer that will extend the pump out far enough to encase the drive coupling and fiber disk. you will also need the teflon high presure hose and the oil filter res.if you need more info on what i did call me at 250 248 2766 mel4104 *4977 |
