Gelecamion (Gelecamion)
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, November 14, 2005 - 2:24 am: | |
hi to all in the us and canada and mexico the upgrade for my 4104 is that now running painted all the wood inside painted the flor red passion red and been working ithe airbags . But i still need some help somebody close tu tucsonb arizona ? Need work in the starting of the bus now i start the bus with a screw driver in the back by the starter because when i try to start it from the button it only makes a click noice , crik , crik , click and that is really fustrating !!!!! |
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, November 14, 2005 - 8:23 am: | |
Sounds like a poor/corroded ground at, or to, the selenoid. |
Brian Brown (Blue_velvet)
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, November 14, 2005 - 11:36 am: | |
Yup. Could be grounds, could be your + wires. Could be both. 12v starters need an insane amount of amps to spin 'em. Work your way back from the solenoid. Check every wire and connection... luckily, there's not too many. If you lightly touch the wires after you've tried cranking, the worst one is usually the hottest. Careful, though... they can get REAL hot. BTDT... Considering the fact that jumping the solenoid starts the engine, you might just have a short on the little wire going to it... and you'd be lucky indeed. OR, you might need a new solenoid, and you'd not be so lucky. HTH, bb |
Stan
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, November 14, 2005 - 3:20 pm: | |
Gelecamion: What is clicking? Is it the the solenoid, or one of the relays in the start circuit? |
Ben Miller
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, November 17, 2005 - 9:59 pm: | |
Hi Gelecamion: I am in the Tucson area, give me a call 520-203-1812 , maybe I can help you find the problem. Ben |
