Jim Barineau
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, November 12, 2005 - 8:34 pm: | |
Sure appreciate this board as a place to find help for a novice. My bus is a 1977 05 Eagle. A friend purchased the shell new and had it converted to a coach in 1978. I purchased the coach in 1992. Total miles on the bus is 200,000 and generally speaking, everything has worked great until recently. Several years back, the ac/heater switch went bad and an Atlanta bus AC company installed a bypass switch so that the bus could operate EITHER on AC or heat. Flip the switch one way for AC; the other way for heat. Worked fine for several years. Now, apparently something has gone wrong with the blower system. Bus still has original bus air and heater system. Problem: no output from either ac or heat. Would appreciate any advice on how to proceed to locate this problem. Hopefully, it is something simple as a switch, fuse, or relay. |
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, November 13, 2005 - 12:18 am: | |
Re: "Hopefully, it is something simple as a switch, fuse, or relay." You answered your own question! But it could be a bad blower (or bad blower brushes) also! |
