Jimbo
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, November 10, 2005 - 12:25 am: | |
I want to drain and flush the cooling system on my 1977 Eagle 05 and am having a little trouble finding the drain value on the heater core. Matter of fact, I can't even locate the heater core. Can someone point out to this novice where the heater core is located and how to get to it? |
Sonnie Gray (Catskinner)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, November 10, 2005 - 9:09 am: | |
Jimbo If you are refering to the Main heater core, it is located between your fuel tanks. Access to it is thru a panel in the middle of your back bay. If you are refering to the drivers area, it is located under the dash in the middle. Hope this helps. Catskinner! Sonnie Gray 72 0/5 Eagle 3406 CAT Pottsboro, Texas |
