Johnny
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, October 10, 2005 - 8:48 pm: | |
How much ATF is needed to refill a V730 in a TDH5300 with a 6V71N for a fluid change? |
Dale L. Waller (Happycampersrus)
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, October 10, 2005 - 10:41 pm: | |
According to the book, 34qts are are required after draining and 36qts after overhaul. Hope that helps. Dale |
Brian Brown (Blue_velvet)
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, October 11, 2005 - 2:02 am: | |
You probably know this, but you can alternatively use motor oil in these... C-4 spec. i.e. 30wt. Rotella, Delo, etc. |
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, October 11, 2005 - 7:55 pm: | |
Brian, That's what alot of the techs recommend. The clark transmission guys recommend it also. They tell me that the the pins and gears last longer with engine oil. I believe the next fluid change I am going to change to 30wt. engine oil. Dale |
