bob m (64.12.102.38)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, September 15, 2001 - 6:33 pm: | |
the shifting rod on my 4104 snapped just above the differential. the shifting rod is not a rod but is thin walled tubing the protective covering had a worn spot that allowed moisture in and caused corrosion and it snapped clean. |
Jim Wilke (152.163.197.209)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, September 15, 2001 - 7:42 pm: | |
Ah-so! But... how did you repair it? Jim-Bob |
bob m (205.188.197.59)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, September 15, 2001 - 11:21 pm: | |
the inside diameter is 3/8 so i put in 6 inches of 3/8 threaded rod 3" in either side with epoxy I also epoxied a sleeve on the outside. i hope it lasts??? |
