dave4106
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, May 22, 2005 - 2:12 am: | |
anybody know if a 6v92ta with a 15 degree tilt out of an rts2 will fit in a 4106? |
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, May 22, 2005 - 6:05 am: | |
If your going to use Transit Scrap , why bother with an Antique engine ? The same bucks will get a DD Series 50 or Cummins or?? A modern 4 stroke will push the milage to 12 or more , although all transit scrap comes with fuel waisting slushpumps.Some are 5 speed tho. You can use (modified) the entire cradle , rear axle with huge brakes and front spindles with sharp cut angle and those big transit brakes too!P/S if you need it for free (if you plumb it up). This will bring the Sportscar of Coaches up another 45 years mechanically , and end the worry of 2 strokes eventually being outlawed by the smog Police. FAST FRED |
Geoff (Geoff)
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, May 22, 2005 - 6:24 am: | |
The RTS engine will not work in the 4106 unless it is modified to the 45 degree tilt you need. This is not worth the trouble-- there are several other transits that have the tilt you need. --Geoff '82 RTS CA |
ned sanders (Uncle_ned)
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, May 23, 2005 - 8:25 am: | |
my 04 has the 6v92 set at the 15 degree level. the only trouble is it is hard to get to the back head. ned sanders huggy bear den |
dave4106
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, May 23, 2005 - 12:56 pm: | |
alright ned sanders, i was giving up hope that anybody had done it. i need to pick your brain on what was involved in the installation. please email me @bluemountaintruck ing@hotmail.com thanks dave |
kelly thompson (Littlelover)
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, May 23, 2005 - 10:30 pm: | |
anyone know what intercity transit makes and models have series 50 detroit engines with the power reverser compatible with gmc hiway buses i have a 4107 am interested in repowering with something better also would like to know any available sources thanks mutch |
Mike (Busone)
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, May 23, 2005 - 11:19 pm: | |
Here are some series 50 engines on esurplus. I know nothing about them. I see them on occasion on this site. http://www.publicsurplus.com/IANAuction?ianac=cat&catid=402 |
